A fitting question.....
/ A fitting question..... #1
mrcaptainbob
Platinum Member
Jackson County, Michigan
Bolens HT-20
I have a Bolens large frame with a FEL on it. The PO used steel line from the valve body to hydraulic hose to the cylinders. The steel lines are 3/8" and use compression fittings. Needless to say they are always leaking. There are compression fitting type T's at the valve to enable equal pressure to each set of cylinders and are used for both directions. I really need to swap this stuff out and use correct hydraulic fittings. The hose ends are the reusable kind. I'd like to use hydraulic hose directly from cylinders to T's at the valve. What are those T's called? Is there even such a thing?
/ A fitting question..... #2
Post a pic of what you call a t, its not a banjo stack is it?
As usual, you nailed it, J-J. Branch tee. So that's what they're called. Thoughtful of you to post those links, too. Thank's, J-J.
2006 MACK CHN613 (INOPERABLE) (A67714)
2006 MACK CHN613...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2013 Lincoln MKX SUV (A66738)
2013 Lincoln MKX...
Shop Cart (A68134)
Shop Cart (A68134)
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
