A fitting question.....
   / A fitting question..... #1
mrcaptainbob
Platinum Member
Jackson County, Michigan
Bolens HT-20
I have a Bolens large frame with a FEL on it. The PO used steel line from the valve body to hydraulic hose to the cylinders. The steel lines are 3/8" and use compression fittings. Needless to say they are always leaking. There are compression fitting type T's at the valve to enable equal pressure to each set of cylinders and are used for both directions. I really need to swap this stuff out and use correct hydraulic fittings. The hose ends are the reusable kind. I'd like to use hydraulic hose directly from cylinders to T's at the valve. What are those T's called? Is there even such a thing?
   / A fitting question..... #2
Post a pic of what you call a t, its not a banjo stack is it?
As usual, you nailed it, J-J. Branch tee. So that's what they're called. Thoughtful of you to post those links, too. Thank's, J-J.
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
2010 INTERNATIONAL DURASTAR 4300 CHEMICAL TRUCK (A55745)
2010 INTERNATIONAL...
