a few problems with MF 231s
   / a few problems with MF 231s #1
gaswamp
First off my 3 point lift will not lower. Hydralic fluid level looks fine. any ideas
Second prob is sometimes when you turn the key it will not crank. You have to do it about 3 or 4 times before it engages. Is there some kind of safety switch. Light come on it just want turn engine over
   / a few problems with MF 231s #2
I have the same tractor. I had an issue with the key switch turning that caused an issue with starting, also move your transfer shifter to ensure it is hitting neutral.
For the lift, there may be an issue with the draft control. Pull the manual for that one.
T
   / a few problems with MF 231s #3
Just realized this wasn't a recent post. If that tractor hasn't been running by now it is probably burnt.
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
(7) John Deere Weights (A50121)
(7) John Deere...
2023 Kubota L2501D 25HP 4WD Front Loader Utility Tractor (A50322)
2023 Kubota L2501D...
2013 Kubota M9960 (A50120)
2013 Kubota M9960...
2004 Ford F-350 Reading Service Truck (A50323)
2004 Ford F-350...
2017 John Deere Gator TS Utility Cart (A50322)
2017 John Deere...
