A few pictures of the Gator XUV
   / A few pictures of the Gator XUV #1
jcmseven
western NC
JD 2320; 4520
Think you might like these...
John M
One more......
John M
   / A few pictures of the Gator XUV #3
Very nice.
Sharpest xuv I've seen.
What size tires?
I like it~!
Skip,
28x12x12 in back; 28x10x12 in front. Steers great, will do 41-42 mph as it sits now based on the car-behind-the-Gator timing, might be 1-2 off--but my wife is pretty precise.
John M
   / A few pictures of the Gator XUV #5
Wow Thats fast for a gator.Chip give it 10 more mph :)
How did they lift it? Is it lifted front and rear?
Skid plate looks nice. :)
Did you get the bed lift?
Very nice xuv.
Congrats
Skip,
I do not know exactly what my dealer did to make it run faster, but he said he got about 5-6 additional mph from the tire/wheel switch and about 5 from "other things." I can attest the machine feels much more punchy than the stock gas (or diesel) that I drove when they first arrived. It accelerates quickly and seems to really move. I also like the way it has enough power to maintain speed up long pulls. The machine has a 2" lift front and rear and does have the hydraulic lift. If you look really carefully you can see the switch to the left of the steering wheel. The stereo is detachable and it and the speakers are outdoor use, so water and weather will not bother them, but I am still keeping it inside except when using. The skid plates are custom fabricated for the machine to provide extended underbody protection. They were the one item that held us up because they were not just right the first time, and my friend is very picky about things. The winch is detachable and can be moved front-rear. I plan to get a snow blade next fall for the winter, and I bet it will plow fine. I also think it probably will go off road OK with the extra ground clearance, real four wheel drive, suspension travel and those tires. Looking forward to getting it dirty around the house. Only thing left is the light bar which is coming. The Gator is already wired up for it.
John M
   / A few pictures of the Gator XUV #8
I have not a new XUV coming this week. I'm not plannng on changing the tires but I would like to get a little more speed. Can you check with your dealer and see what they did to get that little extra push? The radio also interests me. Is that a regular car radio? I know you said it had exterior speakers, where are they mounted?
   / A few pictures of the Gator XUV #9
I really like the look of the spray in liner.
Thats a fine looking machine~!
   / A few pictures of the Gator XUV #10
they had one at the dealer by my house and the guy had the floorboards and the underbody sprayed along with the engine cradle too.it looked really nice.if your gonna go with a bed linner it's best to go with a sprayon or roll on and forget them cheap plastic drop in liners all they do is rub the paint off and cause rust spots.
so what does the skid plate that comes with the xuv look like? cause that one looks like it covers everything really good.
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
2013 Dragon Double Rail Roll Off Trailer (A53117)
2013 Dragon Double...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
2012 Ford F-350 4x4 9FT Knapheide Flatbed Truck (A51691)
2012 Ford F-350...
Dump bed (A51692)
Dump bed (A51692)
ALLISON TRANSMISSION (A53843)
ALLISON...
