A few harvest pics so far
   / A few harvest pics so far #1
D7E
manitoba
Versatile 895 Versatile 876 Ford TW20 Ford TW5 MF 3505 FWA MF 390 FWA Ford 7600 Fiat 766 FWA JD 2030 MF 165 MF 35 Fordson major x 3 CAT 416 b Backhoe Case 580 b backhoe MF
Not too many good pics yet but i had a wet afternoon with nothing to do so heres a few..
   / A few harvest pics so far #2
Now those are "Real" lawn mowers.
   / A few harvest pics so far #3
D7E
In IL. we straight combine our crops. Why do you cut, swath, and then combine your crops?
   / A few harvest pics so far #4
Neat windrower. Sicklebar or disc? Draper or auger?
   / A few harvest pics so far #5
I'm curious as well, Every farm I've seen that operated that
way had a pull type combines. BUT! I don't get out that much :).
   / A few harvest pics so far #6
Must make for long day doing this type of job...glad the ground dry for traction,for up in this neck of the woods ground damp traction can be lousy when cutting corn.
   / A few harvest pics so far #7
I would think that some crops are swathed first then combined, in an effort to allow them to dry down enough. Around here, swathing, when it is done, is done with alfalfa seed. Those fields that are swathed, are not sprayed with a defoliant.
   / A few harvest pics so far #8
do you cut, swath,
In places of shorter growing season the grain does not dry sufficiently on the stalks.
Nice pictures D7E. Have a good harvest and do get some sleep when the dew levels are up.:D
Swathing is the normal for most crops as egon said you often cannot afford to wait and drys down much more evenly and quickly the straw breaks down a little in the swath too making it easier chewing for the combine and better chopping of straw.
For us it is much faster than straight cutting as if you have a few hundred acres already swathed in less than perfect weather conditions you can pull in with a bunch of combines and do a lot of work in a small weather window without the need for expensive straight cut headers.
I don't like waiting for oats or canola to ripen naturally as usually they go flat and shed a lot of the grain before the field is evenly dead....A little diesel swathing is cheaper than dessicating with chemical too.
No doubt other areas have different practices and ideas..Some of the very big "State of the art" outfits straight cut everything but have "Flex drapers" that are more versatile in many crops but their heads are worth more than our combines...?
We have a straight cut and on occasion we do use it but swating just seems to suit our conditions.
Some of these are older but a little more swath action.?
New/Unused AGT 3000PSI Hot Water Pressure Washer (A51573)
New/Unused AGT...
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
Electric Concrete Mixer (A51573)
Electric Concrete...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
