TBigLug
Bronze Member
I just picked up a new to me 4000 (3 cyl. gas) today and wondered if you all could help me out a little.
First can anyone decode the numbers under the hood for me?
S/N: C277906
MODEL: D1424C
UNIT: OF29B
ENGINE: 0E01B
TRANS: 0B19B
First main problem it has is it is leaking fuel out of the carbureator. PO's father in law bought the tractor with it needing a carb rebuild. He did it (he's not mechanically inclined at all). Afterwords it would run but leaked fuel out the carb. They shut it off and left it sit in the polebarn since they bought a new Kubota loader tractor and decided not to use the Ford. Basically it sat there for years until they gave it to my buddy as a housewarming gift (wanted to get it out of the way in the polebarn more likely). He didn't need it so he in turn sold it to me for basically scrap price. I want to pull the carb off and rebuild it properly so i know it's done right. The carb says Holley on the side but all the kits I see are for Marvel - Shebler. Where can I go to find a kit for this carb? Is this an original carb or was it something pulled off a differant tractor?
Any tips or tricks to the clean up and rebuild of the carb or is it pretty straight forward? Should I avoid using the carb dip I used with my truck carbs? I have some experience rebuilding Holley 4-bbl's so I don't think this one should be too hard.
I want to put a loader on it for moving 20 - 40 rounds a year and doing a little bit of dirt moving and manure hauling. I understand from searching the forum that there are two options for front ends. One is stout and can handle a loader and one is not. Mine has bars that run from the front end back to the transmission area. Is that the good one or the weker one? Can a loader still be used on the weaker one with some success?
What model loaders will fit my tractor? I don't want to spend a bundle on a brand new loader so a used one is more my speed. I'm mechanically inclined so mounting one mysef shouldn't be too awful of an ordeal I just need to know which ones to look for.
I want to do a tune up (plugs, wires, cap, rotor, points, condenser, oil change, etc.). Are there any kits out there to avoid or will they all accomplish the same thing?
That's about it for now. I appreciate everyone's help in advance. I just ordered the Shop Manual eBay 400192092662 to start reading up on what I'm getting myself into so I'm sure some of these questions will be answered in there but I like to hear the opinions of real live people who have been there and done that. From what I have read on the site so far, it looks like I got a good deal on a good well built little tractor that should fit the bill for me nicely.
S/N: C277906
MODEL: D1424C
UNIT: OF29B
ENGINE: 0E01B
TRANS: 0B19B
