A few dumb chainsaw questions
   / A few dumb chainsaw questions #1
dgeesaman
Harrisburg, PA
New Holland TC45DA
I've been using a borrowed saw lately (an old school Homelite XL 14") and getting some stuff cleaned up around our property. But the time is coming for it to go back and I should be ready for winter and the fall storm season with my own. I've researched a bit and decided that I'd like a mid-size all-around farm/ranch saw. I've also decided that for another $100 I would be willing to buy a full "pro" line saw if it will work better in my hands and last longer. Based on these criteria I have been looking at Stihl and Husqvarna.
I will use it for:
- Clearing fallen trees (oak, shagbark hickory)
- Breaking down damaged oak pallets
- Removing a couple of junk pine trees and heavy shrubs around the house
- Firewood cutting, maybe. I have 4 acres of wooded land that I can consider for harvesting. Our forced-air allows wood burning or heat pump and I have a good cord of oak to try this thing out this winter.
- For any felling of heavy trees I'll call my boss from work because he does chainsaw work for fun and he has experience with that stuff.
So, some dumb questions:
1) It seems I can get a midrange saw (MS271 or 450) for $400, or for $100-150 more I can get a true pro quality saw. (MS261, 346XP). While that difference is not chump change, if the saw lasts longer, is more serviceable, etc I think that it's a reasonable upgrade to consider. I sense that with what the EPA is imposing on small engines, the average cost of a good saw is going to increase even more rapidly in the future, so the later upgrade will come at a steeper cost. Is this worth considering?
2) If I buy one of the "pro" class saws listed above, is there anything about it that is less appropriate for an occasional user?
3) I have a Neilsen 100B chainsaw grinder in my shop left behind by the previous owner. It looks to be in good shape and very sturdy. While I plan to use a guide/files for most sharpenings, grinding is apparently still required sometimes. Will this grinder serve the purpose? Anywhere I can get a manual?
4) I learned recently that outboard marine engines have a parts availability of about 10 years. Most engines last a lot longer than that, making life very difficult. Does this same crap happen with chainsaws? Between Stihl and Husqvarna, mid-range vs pro, is there a difference in long-term parts availability?
Thanks in advance.
   / A few dumb chainsaw questions #2
that would work fine.i sharpen my chain to 30 degrees.
Referring to the grinder I assume?
   / A few dumb chainsaw questions #4
It comes down to how much are you gonna use the saw, how big of a bar do you want to run, and how much do you want to spend...
I personally look at the weight as the deciding factor...
At my age I want a light and powerful power head...
I would look at Stihl, Husqvarna, Echo, Dolmar, not in any particular order...
Stihl has the most servicing dealers around here but I would not be hesitant on any of those I listed above...
The homeowner type saws are fine for most folk...
   / A few dumb chainsaw questions #5
yes set the grinder to 30 degree angle to grind the chain.
   / A few dumb chainsaw questions #6
We picked up a used 360 Stihl and forget what I paid but could have bought some new in the 200 series for the same money.
I just wished I had bought a professional grade chain saw when I bought my first one 25 years ago. I would have been $500-600 but it would have been worth it.
Unprofessional or professional grade saws all have issues if only used for five minutes every five years. :thumbdown:
   / A few dumb chainsaw questions #7
I will use it for:
When you move up to a "pro" saw you increase the chances of it lasting a long time. Saws won't get cheaper.
Not really. Just try not to put ethanol in it.
Check on arboristsite.com, they have a sharpening subforum that's hard to find, it's under hot saws.
Thanks in advance.
Stihl is very well supported. Parts saws are around for pro saws long out of production. I expect Husky is the same way.
That's what I'm thinking about now, and why I'm leaning toward the bigger purchase.
Yes of course. Just like lawnmowers, string trimmers, and marine outboards. :) Just imagine how much less frustration would exist in this world if the gas had no ethanol and people would follow proper long-term storage methods.
   / A few dumb chainsaw questions #9
Stihl is the best saw made, but the most expensive. Also get a big one, saves time and is nice. Some of the cheap ones work guite well, but you will buy several if you take that route. Also find a capble person to teach you how to sharpen with a file, saves time and trips! Good luck.
   / A few dumb chainsaw questions #10
I don't think need to spend the extra money for the better saw. Doesn't soud like you are going to use it enough to matter.
A home owners will probably last as long if it is maintained properly. There just isn't that much to a chainsaw, the design has been the same for decades. Parts are available.
If you want to spend the extra money for the better saw that's fine but you could spend that money on some other stuff youll need.
JOHN DEERE 50G EXCAVATOR (A52707)
JOHN DEERE 50G...
John Deere M665 Zero Turn Mower (A55851)
John Deere M665...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2025 JMR 40in Brush Grapple Skid Steer Attachment (A55851)
2025 JMR 40in...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A57024)
2014 Doyle Dry...
