SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,394
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Yes. ... Left unsaid, but clear in the graphic, it is the bores offset below the sight that influences the angle where sight and trajectory cross. - This makes a guns characteristic different with regular vs telescopic sights since the telescope sets higher above the barrel.
With standard sight a 30-06 set dead on at 30 yds shoots real good out to about 300. ... AIR, it goes about 2" high at ~100yds and about 4" low at 300.
With scope, higher above the barrel, the 30yd sight in will require a more acute upward correction. Thus the bullet will rise higher above the sight line before beginning to drop.
Only if fired horizontally does drop start immediately. A bullet fired upward is not dropping; its rise is being slowed. The bullet is rising wrt the sight line at first. It is rising more slowly as time progresses. This upward component is decreased by gravity to zero - at which point drop commences.On a technical point...not trying to be **** about it.
The laws of physics state that the bullet starts to drop the instant it leaves the muzzle...aerodynamics of a spinning projectile (not velocity) resists the force...fired in 0 atmosphere (total vacuum) a bullet would not rise...
Air density and pressure are key factors in sniper training...
What do you mean by this? -- At face value its definitely wrong.
,,,larry
