A couple of questions (OIL, FEL)
   / A couple of questions (OIL, FEL) #1
Hellspawn
S.W. Illinois
2011 Kubota B2620
Hi all
Rotella T5 10w-30 ok for my B2620? Anything better to recommend?
Also, I've noticed something odd about my LA364 FEL. When sitting in the seat and the FEL is down lower it seems like it is off-center by maybe an inch or a little more to the left. My brackets on the tractor seem to be OK so I'm not sure if somehow I could have damaged it?
Here's a pic of the FEL issue, definitely not centered.
Thanks for reading.
   / A couple of questions (OIL, FEL) #2
I like the 5w-40 HDEO for all season protection. Philip.
   / A couple of questions (OIL, FEL) #4
That's the T6 version correct?
Can't tell ya. Almost all major manufacturers blend a 5w-40 HDEO. I use Mobil 1 5w-40 TDT myself. But, I think Shell only has one 5w-40 HDEO. Philip.
Added a pic that illustrates the FEL question.
I think it is.
   / A couple of questions (OIL, FEL) #7
Rotella T-5 is what went into my Kubota at the 50 hour service. Next time, I'll likely use the T-6, synthetic, but I don't think the engine cares a bit one way or the other. :D
   / A couple of questions (OIL, FEL) #8
On the FEL/Bucket issue, it is really hard to tell. I know pictures depend on the angle you are viewing etc..
Here is a pic of mine (B2920), and although it seems straight to me, others may look at the pic and think otherwise. In this pic, I was standing on the tractor looking down towards the bucket, trying my best to keep the camera level, ha.
Is the hook on your bucket dead center? If so, what I would do is raise the bucket kind of like you did so it is level with the hood emblem. Then take a long straight edge and place it along the center of the hook, and on the center of the hood emblem, and see if the end of the straight edge crosses over the center of the gas cap or steering wheel. I am assuming all those are centered of course.
   / A couple of questions (OIL, FEL) #9
Another thought. You could put the bucket flush on the ground. Then take a long edge along side the outer side (on the ground), and measure the distance from the outer edge of the tire to the outer edge of the bucket. Then do the same on the other side. They should be pretty close I would think.
   / A couple of questions (OIL, FEL) #10
My B3200 loader is off center to the left about a 1/2". I know I have not bent it so my guess is the Kubota jig is off just a bit when they weld them up or else the welder had just a little too much moonshine.:laughing:
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2019 FORD TRANSIT 350HD VAN (A52576)
2019 FORD TRANSIT...
2023 Ace Cargo 6x12 Food Trailer (A51572)
2023 Ace Cargo...
New/Unused Gold Mountain Container Shelter 20ft x 20ft (A51573)
New/Unused Gold...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
