A couple of hydraulic line-related questions...
   / A couple of hydraulic line-related questions...
A quick update... Because of the insanely high cost I encountered for having two 16-foot 3/8" 3,000 lb hoses made up for my FEL grapple, I decided to make my temporary "bungie cord" arrangement permanent. I did this by purchasing two $10.00 90-degree elbows in order to "stretch" my 14-foot, half-inch (TSC off-the-shelf) utility hoses just enough to reach the front of the tractor with acceptable routing. I am still routing on the left side. I've also given up on finding a "stock-looking" bulkhead bracket for the front of the FEL and will be using cheap and locally-available plastic hydraulic hose clamps to secure the front couplings. While not super-professional looking, and hoses a bit oversized for the task at hand, it will save me a bundle that I can spend elsewhere until I win that big lottery. :eek:
For Galen and 3510/4110 owners: The second hydraulic valve kit turned out to be a bundle of trouble... in large part due to a lack of any installation instructions... but thankfully that portion of my grapple project is now well on its way to resolution thanks to the good folks at MahindraUSA. To make a long story short, the kit was shipped with a short-style lever linkage and valve with front exiting stem. My original valve is long-style lever linkage and valve with rear exiting stem. For several reasons, you really don't want "mix & match" configurations on one tractor. :(
But it turns out that the valve stem is user reversible! :eek: Who knew? :D So in the end, all I really needed was the correct (matching/compatible) long-style lever linkage. MUSA shipped it to me at no charge and it arrived on Friday. BIG THANKS to the folks at MUSA. :)
Other less critical installation issues have all been addressed by MUSA and the good folks down at New England Tractor... plus my own mechanical engineer's ingenuity! :) As soon as the rain stops here and I can drop the BH and remove the seat again, I will finally have my second rear remote set installed and working... EXTREMELY COOL!!! :cool:
Dougster
   / A couple of hydraulic line-related questions... #32
SPYDERLK said:
Dougster, Surplus Center - Hydraulic Equipment Electric Motors has excellent hyd hoses. Stock 4000psi 3/8 15' hoses w JIC 6 or 8 fittings are about $36 ea. NPT fitted hoses are less. Would 15' do it?
larry
16'-3" (+/-2") with 1/2" male NPTF for couplings I have would have been ideal... but 15'-0" would certainly work now with my new elbows. :) In retrospect, I should have figured in the use of elbows all along. :eek:
Funny, but I checked online and found nothing but confusion and high shipping charges... and no "pre-cut" specials anywhere close... so that prompted me to just have them made up locally. Want the prices I found? :rolleyes: Brace yourself...
Nearest hydraulic's shop: Over $75.00 per hose!
High end of range: $102.00 per hose!!! :eek:
Low end of range (best price, but questionable "going out of the business" source): $54.00 per hose.
Now you know why I spent $20 for two elbows and decided to go back to my "TSC Special" :eek:
Dougster
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE MINI...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2022 CATERPILLAR 335 EXCAVATOR (A51242)
2022 CATERPILLAR...
