A clutch question
/ A clutch question
That is sad. �� tractor only has about 175 hours. But I did do some heavy front end loader work a couple years ago. Anyone got a guestimation on what it’d cost to replace? Or suggestions as to not wear out another clutch once repaired?
/ A clutch question #22
I’d guess it’s a warranty issue. Sounds like a bad pressure plate- maybe it had a defect to cause the short life. Other than using the proper gear and having it adjusted properly a clutch should last a long time.....
/ A clutch question #23
Im thinking at least 1k less than 2k for a new cltch by dealer. Hope warranty covers it. With my new tractor resist using clutch except to change gears. Do loader work in low gear where im not tempted to ride clutch at all.
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2025 Fendt 1167 Vario Tractor (A63111)
2025 Fendt 1167...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
Bobcat A770 (A60462)
