A/C Temperature?
   / A/C Temperature?
The man on the service truck seemed like a **** good and knowledgeable mechanic/trouble-shooter. He had to work on the a/c 3 times to finally resolve this. Once, he replaced a faulty water valve and once JD sent him the wrong a/c line part to replace. He seemed to really enjoy his job and was always upbeat and in a good mood....even when he wasn't able to arrive until well after 5:00 after working hard all day only to work much later on my tractor. He seemed determined to resolve the problem. I was very impressed with him.
   / A/C Temperature? #52
Probably some guy on the assembly line did it to mess with a poor mechanic.
That can happen. Many years ago there was a rumor going around and heard it enough to believe it, that somebody on the auto assy like would drop his pop bottle down in the door before installing the upholstery to help and deal with their boredom......and then there was a guy out in California that drove or pushed a Ford Pinto off the top of a stack of them (seems they stacked them vertically at the factory to free up floor space awaiting shipment) onto the floor, some 15+ feet high. I saw pictures of this one....fact.
Mark
   / A/C Temperature? #53
In my case it turned out to be a rupture in the evaporator….had to lift the `house` up a bit to get to it and replace…..Dealer `stood` for the costs……Tony
   / A/C Temperature? #54
I just got a new B2650 and tried the a/c today and all it did was blow warm air . I looked at the sight window the manual says to look at and it is clear as a bell which according to the manual says it has to much gas or none , I am thinking none or very low . The dealer is 60 miles away , you would think they would check things out before delivery .
   / A/C Temperature? #55
HEC
I'd suggest to get someone local with a set of gauges to check the coolant charge pressures.
   / A/C Temperature? #56
I'll call the dealer Tuesday , I'm sure he will take care of the problem . Thanks for the input Tx Jim
   / A/C Temperature? #57
Up date on the A/C problem on B2650 . When they mounted the radio as they were pushing in the mounting bracket it disconnected some wiring for the A/C.
   / A/C Temperature? #58
In my case the a/c was not fixed, as it now just blows warm air….Talked to the dealer, who says i`l have to have it fixed myself….Bobcat was delivered with several things that were wrong--one in particular was the broken jerk that let the grease out on the track, which then came off…Took me two times before I got that fixed, only to find out it was a known problem. Then a leaking oil fitting….Unfortunately the dealer here in Chas s c does not have a decent mechanic, so I go to the Kubota dealer, who is reputable……I really wonder why the manufacturer does not have a thorough checking system…I purchased because made in usa means something to some American human being, but one can experience for themselves how other Americans in the chain , can sour the situation for everyone…..I`l report how the outside repair turns out Tony
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
GAME FISHER 5HP OUTBOARD MOTOR (A58374)
GAME FISHER 5HP...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
2023 CORAS PREDATOR 28FT DUMP TRAILER (A58018)
2023 CORAS...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
24in excavator tooth bucket (A56435)
24in excavator...
