A/C refrigerant oil question
   / A/C refrigerant oil question #1
Harry in Ky
Winchester Ky
Allis Chalmers ED 40
It seems to me that the process of evacuating a system prior to charging will not only remove the air and moisture, but must also remove oil from the compressor as well. The oil level in my vacuum pump always rises when I pump out a system after installing a new compressor with a measured charge of oil installed. If this is the case, then what's the point of the careful measuring/pouring of oil into a compressor, evacuating, and then measuring more oil to be installed with/ahead of the refrigerant? Many new or reman compressors come with oil installed and often with a tag stating the specific quantity installed. It somehow seems pointless since no compressor can be installed and charged without first being evacuated.
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
METAL FILING CABINET (A53843)
METAL FILING...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
