A/C refrigerant oil question
   / A/C refrigerant oil question #1
Harry in Ky
Veteran Member
Winchester Ky
Allis Chalmers ED 40
It seems to me that the process of evacuating a system prior to charging will not only remove the air and moisture, but must also remove oil from the compressor as well. The oil level in my vacuum pump always rises when I pump out a system after installing a new compressor with a measured charge of oil installed. If this is the case, then what's the point of the careful measuring/pouring of oil into a compressor, evacuating, and then measuring more oil to be installed with/ahead of the refrigerant? Many new or reman compressors come with oil installed and often with a tag stating the specific quantity installed. It somehow seems pointless since no compressor can be installed and charged without first being evacuated.
2023 Yamaha R Max XTR  (A52384)
2023 Yamaha R Max...
Landoll Hauloll (A53473)
Landoll Hauloll...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Syrup Kettle (A50123)
