Dadnatron
Veteran Member
JD 5100e about 1300 hours out of warranty.
Last summer, I had to recharge the AC coolant and it seemed to work for the rest of the year. Of course, I didn't think about it until this weekend, when I was spraying and it was getting hot. Blower works, Compressor kicks in, but no cold air. I checked pressure and it was extremely low.
Off to the store, picked up some 'freon' and recharged it back to 'green'. It cooled off just fine, but within just a few minutes, it was right back to where it began.
So... I have a leak. I'd rather NOT take it all the way in to town and have to deal with the hassle if there is a likelihood that I can fix it.
I have never tried a STOP LEAK product on this tractor. I've used it on an old 4Runner I had, and as far as I can remember, it worked fine.
I've read many 'theories' on the net about how awful the A/C stop leak is... that it clogs up the system and basically ruins it all. But I understand the theory and why it 'might' work. However, I don't want to screw something up that will only cost me more money. If I have to have someone fix it, I will, but I don't want them saying I cost myself even MORE because of the stop leak attempt.
I'm not opposed to changing hoses/pipe/etc. I have NOT charged the system with a 'leak detector' and can certainly do so. Do you have any recommendations about a good version?
Basically... 1. does a leak stop hurt my tractor. I'd like experience here, not assumption. And 2. is a leak detector marker worth it? I've tried it on other vehicles at times, and never ONCE have I found the leak. 3. If JD 5100e's or other, have 'common A/C problems' that are owner fixable, where would you recommend I begin looking?
