A Bad Day
/ A Bad Day #11
I'm considering removing the oil pan first, to see if the intake tube fell off, or as you suggest, got plugged somehow... Can't think of anything else to try.
No horrible noise, so that's good. I guess I'll start by removing the front drive shaft and the oil pan to check the pickup tube, but I'm not terribly optimistic. Seems like the next steps will involve removing the whole front end of the tractor, so the drive shaft would be the least of my worries.
Id start with the oil pressure switch.unless that’s what you’re calling the sending unit.
/ A Bad Day #12
The problem lies with the pump or related to the pump.
Check all plumbing related to the pump if the tubing is
clear and the pickup tubing is not disconnected from the
pump then its the pump that needs replacing.
willy
/ A Bad Day #13
Chevy had a re-occurring problem where the o-ring seal between the pickup strainer and the pump failed. I have that issue right now. For some reason, your pump is either not picking up oil, or not able to produce the pressure required. Without knowledge of your unit, my gut tells me to pull the pan and inspect, starting at the pickup tube and going up from there without any other symptoms presenting themselves, such as oil in the coolant, knocking, squealing, etc.
/ A Bad Day
Found the problem! Sure enough, it was the pin that holds the driven shaft to the pump "vane" (if that's the right word) which had sheared, so the shaft turned but the pump did not. I could probably just replace the pin, but if a whole new pump is not too pricey, I'll replace the whole thing in case there was any unseen damage from the end of the pin grinding around in the pump before it sheared off.
Thanks All, for the advice and encouragement! Pulling the front off wasn't too bad, other than the one lone stud that went through the backing plate to a nut that was very hidden behind the hydraulic pump!
/ A Bad Day #15
One of the most valuable things a poster can do is come back to explain the solution.
Thanks for that!
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59908)
2017 FREIGHTLINER...
iDrive TDS-2010H...
DOOSAN G25KW GENERATOR (A60736)
DOOSAN G25KW...
2000 Sterling L9513 Winch Truck (A61307)
2000 Sterling...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
