A 60' walk/4wheeler bridge......:
   / A 60' walk/4wheeler bridge......: #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
I have been thinking about a bridge over our creek for 7-8 years. It's 50+' bank to bank...so it was a lot of thought.
I came across a welded bridge frame at an auction. It was built out of mobile home frame(10" 1/8th I-beam) 60' long, 45" wide & it looked sturdy enough. I cut it in half, to load it and get it home where I welded it back together. I used the Kioti to pull it down to the creek. I attached a cable in a Polpar tree on the opposite bank and pulled it across with the tractor(bridge on it's back). When I tried to turn it over it pretzled(yes my splice held), so I pulled it back across and used the FEL to straighten it back out. I have a 25KW pto generator, so I hooked it up and used my Millermatic 210 to weld in 10" I-beam cross braces every 6'(the original one's were 4" and real thin metal) I added a support under the bridge angles for extra support.
The second try was succesfull, so I poured concrete footers at each end and bolted the frame to the footers. 2x6x20 PT(120') was lag bolted to the top of the bridge I-beams, then 4' 2x6 PT planking screwed down with 3" Torx deck screws. This really made it more stable, but I am still going to sink 2 utility poles at each end, run a cable across and stanchon the bridge is several places with cable. Only then will I drive my wheeler across. So far I have about $500 in it(and a ton of time:thumbsup:). This creek floods several times a year, so that is why it is so high...to keep debris from catching it and pulling it down stream.
Welding it back together:
Note the tiny cross braces:
On the road to the creek:
   / A 60' walk/4wheeler bridge......: #2
Lookin good moto! I need to do something similar in the future over a creek.
Whatever happened with the house.....on hold?
Good to see you back!
Frank
Footer(it's 2'deep and rebar'd):
Cutting the planks:
planks:
Just say "No" to crack:
It's about 12" off the water:
And this is what is planned to reinforce it:
   / A 60' walk/4wheeler bridge......: #6
Nice Plan! Well Done! :thumbsup: I need to follow your post and progress. I have a similar need over a swamp....tho not so high.
   / A 60' walk/4wheeler bridge......: #7
VERY nice thanks for the pictures
   / A 60' walk/4wheeler bridge......: #8
Motorseven
Compliments on a job (big job) well done.
I'd only suggest adding some cable from the post tops to the bridge beams to stiffen up the bridge (red lines). As shown, there won't be much if any stiffness or lift on the center of the deck.
Bt, I will try an rustle up enough cable for that..thanks.
Foggy, I thought the proper Yank term was "slough" or "slew"...?
Back home in Louisiana it was all 'swamp":D
I did get over 650 lbs of buddies on the bridge & it looked like a half inch of deflection in the middle. I still won't drive on it until it gets the cables since I am worried about the oscilliation from the wheeler tires.
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
Informational Lot - Financing (A55302)
Informational Lot...
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
2009 Pierce 105ft. Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
