9n rear end problem
   / 9n rear end problem #1
Burrell
farmall super c, 9n ford, allis chamers b, kubota L 3300, ford 4500 backhoe
I was using my 9n the other day leveling out some dirt with my scrape blade and got to noticing a little binding when trying to change gears from reverse to first and some clanking sound out of the left rear axle also was acting like the brake were stuck but the kicker is when you put the pto lever to off position every things fine shifts good no noises or binding I'm not shour exactly where to start looking for the problem. I'm wondering if anyone has run into this before any advice would greatly be appreciated thank's
   / 9n rear end problem #2
since the pto is running a hyd pump and it's all off the non live clutch, it's all semi-related.
check to make sur ethe bellhousing drain at the clutch / block mating point is open. wet clutches will make them sticky and drag
post back
just got around to checking it and it seems to be fine. I believe it's a bad bearing really not shour.
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2011 CHEVROLET EXPRESS SERVICE VAN (A51406)
2011 CHEVROLET...
