9n rear end problem
   / 9n rear end problem #1
Burrell
farmall super c, 9n ford, allis chamers b, kubota L 3300, ford 4500 backhoe
I was using my 9n the other day leveling out some dirt with my scrape blade and got to noticing a little binding when trying to change gears from reverse to first and some clanking sound out of the left rear axle also was acting like the brake were stuck but the kicker is when you put the pto lever to off position every things fine shifts good no noises or binding I'm not shour exactly where to start looking for the problem. I'm wondering if anyone has run into this before any advice would greatly be appreciated thank's
   / 9n rear end problem #2
since the pto is running a hyd pump and it's all off the non live clutch, it's all semi-related.
check to make sur ethe bellhousing drain at the clutch / block mating point is open. wet clutches will make them sticky and drag
post back
just got around to checking it and it seems to be fine. I believe it's a bad bearing really not shour.
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2009 Dodge Grand Caravan Passenger Van (A53117)
2009 Dodge Grand...
Hose Reel (A53424)
Hose Reel (A53424)
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
2016 Chrysler Town and Country Van (A51694)
2016 Chrysler Town...
