990 Questions
/ 990 Questions #1
FLDave
West Central Florida
JD4320, loadmatch, speedmatch, motionmatch, automotive cruise, r4's
Hi All,
I've had my heart set on a new 4320 for a while but I've also been keeping my eyes peeled for a good deal on a used tractor.
I just found a 4wd JD990 with just a little over 100 hours on it. There's a small scrape on one fender and the oil is black.
The seller wanted $12,000 for it and I got him down to $11,400. It comes with a boxblade and I don't think it has scv's for a fel.
I have but a few questions:
I don't think it has scv's to hook a fel loader to. Can you even buy a 4wd 990 without scv's?
How much would it be to add dual scv's so I could put a loader on later?
A 990 is 40hp and 35 PTO hp. A 30hp PTO is supposed to be able to operate MX6 cutter. Are there any aftermarket 6' rotary cutters (medium duty) that a 990 could run?
I have 15 acres of cow and horse pasture. Should I wait and get a slightly stronger unit?
The front end of the 990 seems VERY light. So light that when I first drove it I popped the front wheels off of the ground a few times on take off with the boxblade on the back. Can this be cured with practice or are front weights inevitable?
Oh Yeah, and is the price I got decent?
I'm supposed to see the guy tomorrow morning so comments on any of this is extremely appreciated.
Thanks,
/ 990 Questions #2
Dave, a couple of other things. I got dual SVC'S with the tractor and only paid $8500 for the rig. The guy had paid 38 notes on the 990 but still owed $6500 to JD. I paid JD off and gave him $2000 cash. Some deal, huh?
/ 990 Questions
Robert, even I know that you got a once-in-a-lifetime deal on your tractor set-up. /forums/images/graemlins/laugh.gif
I just want opinions if I should buy the unit mentioned. /forums/images/graemlins/confused.gif
If I try to wait for a deal like yours I may never own a tractor. /forums/images/graemlins/wink.gif
/ 990 Questions #4
"The front end of the 990 seems VERY light. So light that when I first drove it I popped the front wheels off of the ground a few times on take off with the boxblade on the back. Can this be cured with practice or are front weights inevitable? "
It doesn't take much RPM to move the machine. Try setting the hand throttle at 1200-1500 RPM and let off the clutch smoothly. Then increase the engine speed using the hand or foot throttle. You might need the weights, but if you're thinking about a loader..I'd save that money to put into the loader
You do have the 3PH, so the hydraulics are there. Now....you might check with a local dealer to determine how much it'll cost to add the loader. I assume this tractor has a joy stick? If so, you're halfway there...
As far as any aftermarket cutters...you'll find a wide variety that the 990 has the power to operate. That won't be a problem! I've a Land Pride (60" unit) I am very happy with!
I think the 990 would be a good match for your 15 acres. I do think you'll want a loader though...and adding a 430 loader might be a showstopper for this particular tractor. So, check the cost of adding a loader before you buy.
/ 990 Questions
Roy, thanks for the input. I didn't see a joystick for a fel. The reason I was asking about scv's is that I didn't see those colored plastic caps on the rear end that cover the hydraulic line connectors.
If that's the case, my closest dealer wants like $1,460.00 for hydraulic connectors, etc., ... and $3,500.00 for the loader. Unless on the 990 they put them somewhere other than the rear end and I just didn't see them. I was on my way to Miami and I jumped off the highway to take a quick look at the tractor. In my haste I may have missed seeing them but they definitely were not on the rear end.
I'm starting to think if I haggle with a dealer I may not be that far off on a new unit. The problem is, the local dealers say that they don't have as much margin on the 790, 990, 5105, & 5205's. This may or may not be true but that is what they're feeding me anyways.
It was funny, the first time I drove the 990 I was driving it like a standard car and while I was letting off the clutch I was pushing down on the gas pedal. I achieved some good wheelies doing that. /forums/images/graemlins/blush.gif
/ 990 Questions #6
"I'm starting to think if I haggle with a dealer I may not be that far off on a new unit. "
The 990 lists for just under $14K new (MSRP on the Deere website).
I'd try machinefinder.com ( Link here ) and see what you find online.
If you need to add the loader and hydraulics..you are real close in price to a new machine.
I think the 990 would be a good fit..I also think a 4400 or 4300 would fit just as well. Didn't see many 990's on Machinefinder, but there's a bunch of 4300's and 4400's.
/ 990 Questions
Roy, It's a 4wd which I believe list new for over $17,000.00. I still think that maybe it's not the greatest deal though.
Thanks for the link.
/ 990 Questions #8
I have a 990 with an MX-6 brush cutter, and it works well, it's not really enough tractor for the weight. The horsepower is probably also marginal. It really drags the engine down on startup.
Tennant 5680 (A64127)
Decorative Alligator Statue (A61574)
Decorative...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
