990 owners and round bales
   / 990 owners and round bales #1
Dutch445
Elite Member
Upstate NY
JD X585
Are there any of you 990 owners out there that can help
me size a tractor. My customer has a 790, and knows he
can't lift the round bales he gets in winter for his horses.
He is thinking of buying a 990 with the 300CX loader, and
a bale spear to unload the truck and move bales around his
property, then drop them into the feeder which is 5-6' high.
is anybody using their 990 with a FEL bale spear and moving bales?
how big a bale can you use? He's looking to move 900 lb bales,
but they are a little heavier in winter when they take on a little
water.
thanks in advance.
Dutch
:cool:
   / 990 owners and round bales #2
Keep the rear ballast weights on and get a substantial enough amount and fill the tires. Tell him to go slow. That or sell him a 4320 and 400X.
thanks Mike,
Anybody else with an opinion or experience?
   / 990 owners and round bales #4
Unbelievable timing, because I just moved 3 bales yesterday. Bales were between 4 and 5 feet, and did it with no problem. I had the brush cutter on the back when I did it. They were pretty dry bales though. Hope this helps.
thanks for that post,,
when you say the bales were between 4-5 feet,
is that the diameter? and , how wide are these bales?
this guy gets 5'wide bales,, and they are about 4'
across in diameter,,, and weigh 900,,, we feel
we are close to the limits here with the amount of
weight that size bale puts in front of the loader...
   / 990 owners and round bales #6
I might be a little off in my weight estimates --- but isn't the lift capacity of the 300CX just shy of 1,500lbs? The measurement point at the bale spear might lower the useful capacity a few hundred pounds --- however, I'd still like to think you'd have a good working margin over the 900lb bale weight. Concern would be correct/adequate ballast and sensible use of the loader when carrying a bale; i.e; low to the ground and slow until dropping the bale into the feeder.
AKfish
   / 990 owners and round bales #7
I'd be careful, if the weight from a spear is much further forward than a bucket (and I assume it is) you get a lot of extra torque to lift the rear wheels off the ground.
   / 990 owners and round bales #8
Hi Dutch,
Can't give you any help on the round bales... I have carried some loads though...
The 300CX (with 72" HD bucket, repl cutting edge, chain hooks) can routinely pick a heaping full bucket of clay up over 9 feet; a stacked bucket piled full of ash (wood) "built out" two feet from the bucket edge...
Most pertinent: it can load an MX-5 cutter chained inside the bucket (rear wheel straight out) onto the back of a truck no problem (except dented wheel wells!). It didn't sit well--needless to say unloading went even smoother.
With the gearbox & tail wheel I'd say the center of gravity on that load had to be at least 36 inches out from the cutting edge; ~730 # cutter, ~200# bucket, ~20# 3/8 chain.
I had ~775 pounds of box blade/weights on the back of a 3320 and no fill in the tires for all the above... and bouncing for everything.
If you have an MX-6 on your lot, that would be a real good "real world" test for the 990/300CX combination I would think.
I'm guessing 900#'s low & slow to drop-off with rear ballast wouldn't make that loader flinch a bit... maybe the operator;)
   / 990 owners and round bales #9
The bales were 4 to 5 ft. in diameter, and about 4 ft. wide. As a side note, tried to lift 72 sheets of 1/2 in. OSB 2 days ago, but couldn't find any strapping to hold. The bales were no problem though. Didn't even grunt much. I am having alot of creep down in the loader hydraulics though. Wish Yanmar made the loader too.
We put the tractor together and I grabbed some wheel weights to
see how well the tractor would handle the bales. The pictures show
2 450# weights and 1 165# weights, which equal 1230#.
When I fist slid the big weights on, they didn't go much past
the bottom spike and were about 10" out in front of the frame,
As I lifted the load up high, and let the load curl back a bit,
the weights pushed a bit further back toward the frame, so now
the weight was closer to the pivot point on the loader.
With the load at about 66" of clearance, the tractor would still
lift higher, but I could feel the rear getting a little light. The tires
are not loaded yet, but would be if the customer buys the rig.
here are a couple pics of the load
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
Deere 333G (A53314)
Deere 333G (A53314)
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
John Deere 2305 Compact Tractor (RIDE AND DRIVE) (A50775)
John Deere 2305...
1994 21ft. Aquasport 210 CCP Division Boat with 24ft. Continental T/A Boat Trailer (A55758)
1994 21ft...
