99 S10 ABS problem
   / 99 S10 ABS problem #1
gugy
Bronze Member
Upstate New York/Holbrook L.I.
BX 22
I have a '99 S10 that the ABS comes on at low speed stop.No codes in the ABS system and no idiot lights on dash. The pickup has fairly new front hub/ bearings which come with brake sensors. I changed the top portion of the brake controler and still have the problem.I know its the ABS because when I pull the fuse the problem goes away but Naturally I get an ABS warning light on the dash.Any help would be appreciated
Thank You
Bob
   / 99 S10 ABS problem #2
You need to clean off the wheel speed sensors - hopefully not replace them. GM had problems here in the Midwest "salt belt" that led to a recall - but i don't know if that covers New York. It was only a regional recall. I would talk to a Dealer and see what they will do for you. Hope this helps.
   / 99 S10 ABS problem #3
we have a 99 suburban that had problems with the abs- failed at low speeds. It was NOT covered under the recall. My mechanic told me he clean the sensors and hopefully it would fix the problem- but he may break them while cleaning- a $60.00 per side job could go to $600.00- and he did not know which side was faulty. I pulled the fuse and drove with out ABS for a while. We had a bearing fail and it ended up to be the culprit. I've had two other trucks ( ford and gm ) that gave ABS failure lights when the bearings went.
strange that you are not getting an indicator light?
I want to thank you guys for the reply.I still can't fix my problem.
Both front sensors are clean,I called the Chevy dealer and they checked with my vin number for a recall. No such luck.I guess I'm going to have to bypass the ABS by removing the fuse.
Once again thank you.
Bob
   / 99 S10 ABS problem #5
You might check the speed sensor in the rear differential , if you haven't already
   / 99 S10 ABS problem #6
bob call 581-0484 and make a appt if you want
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
