'99 F250 7.3L PSD Issue- Suggestions
   / '99 F250 7.3L PSD Issue- Suggestions #21
now don't go scarin' him all the way :)
a lil turbo whine is common on just about any tc'd machine.. that lil canary that lives in there makes noise that is just hard to 100% block.. :)
soundguy
   / '99 F250 7.3L PSD Issue- Suggestions #22
There is a TPS, actually two, on the throttle pedal. They are not serviceable, you have to replace the pedal assembly. Usually you get a "dead pedal" when they go out though. The truck will idle, but that is it.
Chris
Well, so they say.
My proving switch started working intermittantly, so I removed the pedal assembly, sprayed down the microswitch with WD-40, blew it down with air and reinstalled it.
That was 5 years ago. Never failed since.
   / '99 F250 7.3L PSD Issue- Suggestions #23
Well, so they say.
But, if the switch goes bad, you replace the pedal assembly.
Chris
   / '99 F250 7.3L PSD Issue- Suggestions #24
soundguy
Not trying to scare him away, but after some of the earlier replies he got, I thought he might want to consult some Powerstroke "experts". :D
Chris
   / '99 F250 7.3L PSD Issue- Suggestions #25
The powerstroke's fuel system is not like what you would find on your "normal" diesel. There is no high pressure fuel pump or injection pump, only a 70 psi lift pump on the frame rail under the driver's seat.
The problem is not the pedal assembly. It's fuel supply.
   / '99 F250 7.3L PSD Issue- Suggestions #26
I agree about fuel problem. When you drive day after day hauling cattle long distance with no engine problems then purchase fuel and cannot get out of town because of water in fuel.
Drain filter and then 15 miles later again drain filter replace filters and still on first hill of any height get the water in fuel light come on. Hauling at night to let the 4 whl'rs with kids to get home and so not pass you and slow down or drive beside your trailer tires.At this time of night all repair shops are closed also.
Guess I'm different because I work with a group that don't care what type of rear end gears or type of trasmission. Mostly discussion is will the truck get the job done or is it likey to be sitting in some shop for repair. When you can't deliver on time some one else has the job. And they don't care about type of truck .
Guess it is to late at night.
ken
   / '99 F250 7.3L PSD Issue- Suggestions #27
that's why I carry:
1 bottle of seafoam
1 bottle of PS water dispersant
1 bottle of either white or silver PS
in my truck tool box.
every fill up gets a lil of the white/silver bottle.. If I suspect water, then some dispersant. If I actually KNOW there is water as i have just had to drain a fitler, then it gets the seafoam.
betweent he 3 I've never been stuck on a roadside for very long.
once you get the water out of a glob on the bottom of the tank and from the lines and from plugging the filter and filter bowl.. it all starts to move.
soundguy
   / '99 F250 7.3L PSD Issue- Suggestions #28
Don't forget about the mechanical lift pump near the valley of the engine under the turbo. R&Red an engine for a guy in a 96 F250 5 or so years ago who had the pushrod for the pump fall down into the pan when attempting to change the pump himself.
   / '99 F250 7.3L PSD Issue- Suggestions #29
The '99 and newer trucks do not have that pump. They use an electric pump on the frame rail.
   / '99 F250 7.3L PSD Issue- Suggestions #30
change the cps sensor ,there is a recall on them.it can cause the truck to idle ,then run like nothing is wrong.the high pressure pump is that round thing under the fuel filter .it is not a injection pump.
   / '99 F250 7.3L PSD Issue- Suggestions #31
The high pressure oil pump is that rectangular looking think in front of the fuel filter assembly, not the round thing under the fuel filter.
Did you ever visit thedieselstop.com ?
Chris
   / '99 F250 7.3L PSD Issue- Suggestions #32
Uh, no.
That rectangular thing is the high pressure pump RESERVOIR. The HPOP is under the fuel filter housing.
To the OP, as has been stated numerous times by those that have a clue, you likely have a fuel supply issue. Have a mechanic install a fuel pressure gauge at the head and road test with the trailer. If the pressure drops even with a new filter, then either the pump is bad or the sock in the fuel tank is plugged. Both are very common problems. You can blow air backwards through the fuel supply line before the pump to temporarily clear debris from the sock. If it road tests normal after this, then you will need to drop the tank and clean the sock or eliminate it. There are plenty of write ups on the web about this procedure.
Also, the PSD trucks will run without the electric pump operating as they have the ability to siphon fuel from the tank. The trucks will often show a lack of power on a long hard pull but will otherwise run pretty much normal. However, once the system is opened, like when replacing the fuel filter, the system will not prime and the truck will run for a few seconds then quit and not restart. The electric motor section of the pump usually works fine, it is the pump section that fails. So, just because you can hear the fuel pump running doesn't mean it is actually producing useable flow. Something to be wary of as you sort this out.
Don't waste time with the CPS, it cannot cause your concern.
Jay
   / '99 F250 7.3L PSD Issue- Suggestions #33
   / '99 F250 7.3L PSD Issue- Suggestions #34
Uh, no.
Jay
Jay's got it right. I am amazed at how many people have responded that do not know what they are talking about. Hard to understand why you would open your mouth when you obviously aren't certain about the facts. It's great that you all want to help but spewing false information is counterproductive.
Only the old powerstrokes had that mechanical lift pump in the valley. The modern 7.3s, the 99 and ups which are the subject of this thread, have replaced this lift pump with an electrical one on the frame rail.
True, the CPS has been recalled and the new grey one has worked very well for me. This has nothing to do with the problem that the OP is having which is lack of adequate fuel supply under load.
   / '99 F250 7.3L PSD Issue- Suggestions #35
good reading, especially since i am pretty close to picking up a 2000 Ford w/PSD. Not really sure what i learned here, but in my 20yrs of self employed truck driver...............I'm with highbeam. You got fuel delivery problems. As some others point out, change filter first. preferably dump the filter in a clean bucket. Actually i use windshield wash jugs with the top cut off. dump it upside down and let it settle. There will be minor deposits, but look for the water separation. Good Luck. Probably more than just a filter problem. But if you got water in the fuel, and it spoils the injectors? Might get pricey. But the PSD is a tough one.
   / '99 F250 7.3L PSD Issue- Suggestions #36
The 7.3 Powerstroke doesn't have a spin on fuel filter. It has a canister type between the heads, at the front of the engine. If you pull the little yellow lever on the passenger's side of the fuel bowl, it'll drain the bowl.
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
UNUSED FUTURE TBL47-47" HYD TELESCOPIC BOOM (A60432)
UNUSED FUTURE...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
