98-01 Ram 2500-3500 cummins failure
   / 98-01 Ram 2500-3500 cummins failure #1
MyJoBota
Upstate New York
Kubota Grand L5740
98-01 Dodge Ram 2500-3500 cummins isb 5.9l diesel engine built with a pattern 53 engine block. How many of you have seen engine block failures with these such as cracks on passenger side causing coolant leaks? :anyone:
   / 98-01 Ram 2500-3500 cummins failure #2
I have not seen that ... I did get a notice about a class action lawsuit regarding this.
   / 98-01 Ram 2500-3500 cummins failure #3
Have seen a couple here at the dealer.
   / 98-01 Ram 2500-3500 cummins failure #4
I've never seen it, but have heard about it. I think it is repairable.
Do you have the problem ?
It's one of 2 known problems with Cummins 5.9 engine, that and the killer dowel pin.
Both affected a small percentage of engines, but there is nothing else to bash a Cummins for, so it does get mentioned often.
JB
   / 98-01 Ram 2500-3500 cummins failure #5
I thought they would warranty all cracked "53" blocks with less than a zillion trillion miles on them?? I remember this being a problem back then but haven't heard anyone mention it in years.
   / 98-01 Ram 2500-3500 cummins failure #6
I know of one. It was welded and traded ASAP.
Chris
   / 98-01 Ram 2500-3500 cummins failure #7
Chris
Don't know why it would need to be traded ASAP.
Cummins owned up to it and from what I understand, it would never lead to a catastrophic failure (unless you never replaced the coolant lost) Was basically a low pressure coolant leak, through an otherwise robust casting.
That's what I heard, I may not have the whole storey
The fact that it could be repaired tells you something about that block IMO.
JB.
I also received a notice about the class action lawsuit. I do have one of these trucks and just curious how many of these engines have developed this problem.
   / 98-01 Ram 2500-3500 cummins failure #9
are you kidding?... somebody sent you recent info on a class action lawsuit of a 13-14 year old cylinder block???? It was only the 1998-1999 year models that had the potential to fail....
There are several repair methods for repairing the block...
   / 98-01 Ram 2500-3500 cummins failure #10
I think that went on up to the 2001 year also...
Dad has a 2001, but has never gotten up underneath it to check to see which casting he has. I recently told him about the "53" block, and where they were cracking.
His truck doesn't have 40,000 miles on it yet, so that 12 year old block should be like new.
David from jax
Those owners of a Cummins 24v ISB engine in a 1998-2001 model year vehicle. This does not only affect Dodge Rams. The 53 block was also used in medium duty trucks from different manufacturers, mobile homes, public school buses and mass transportation buses.
http://www.stamey.info/Truck/Cummins53BlockFAQ.htm
RING 3 STARTS HERE @ 9:30 AM (A51248)
RING 3 STARTS HERE...
1999 CAT TH63 (A50123)
2016 Peterbilt 567 Tri-Axle Dump Truck (A51692)
2016 Peterbilt 567...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
90018 (A48082)
90018 (A48082)
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
