'97 Foreman 400 no spark
   / '97 Foreman 400 no spark #1
luscsmith
My foreman all of a sudden stopped running. After a month of checking, testing and reading I replaced the voltage regulator and now all is good.
I just wanted to share this as it might help someone else.
Scott
   / '97 Foreman 400 no spark #2
Thanks for the info!!!
   / '97 Foreman 400 no spark #3
There is an AC sensing wire that is attached to the voltage regulator that is also wired to the CDI box. they CDI receives this signal to tell it the engine is cranking. What happens is the voltage regulator shorts out and grounds the AC sensor wire and the CDI can't get the signal therefore no spark.
Walk-Behind Automatic Seed Spreader (A51691)
Walk-Behind...
Vermeer 840 Discbine (A50774)
Vermeer 840...
toro turf sweeper (A50324)
toro turf sweeper...
John Deere 637 Disk (A50514)
John Deere 637...
JLG 4045R 40ft Electric Scissor Lift (A50322)
JLG 4045R 40ft...
