96” land plane suggestions?
   / 96” land plane suggestions? #11
My Kubota with FEL, grapple, RimGuard in the rear tires, R1 tires all around and 1000+ rear blade - weighs a tad over 10,000 pounds.
I have quite a few places on my property where multiple, shallow passes are the best way to go. The idea is to work the soil - not break the equipment.
You have a good time with your new implement.
   / 96” land plane suggestions? #12
Our LS land plane was purchased without scarifiers and am glad I didn't
get them as this unit works well without them.
willy
   / 96” land plane suggestions? #13
Willy - not needing scarifiers - you are fortunate. The surface of my mile long driveway - gravel, sand, silt & volcanic ash. It turns to concrete during the summer.
Even my heavy Rhino rear blade has trouble breaking this crust. I need something that will break this crust. I can then move into repair of pot holes and my one muddy section.
Sometimes I really do envy those with the beautiful screened gravel driveways. But not from the standpoint of cost.
My vote is for a BEFCO. I just bought a 72" to pull behind my SA425 and it has no problems with it at all. The BEFCO was almost #200lb more than the competing Frontier model and other name brands. I have a 60" Frontier (Bought last year) also and the BEFCO does a better job IMO.
Your tractor will handle a 96" fine. My tractor with loaded tires and loader is under #3k lbs.
Your tractor with loader is probably close to #5,500lbs more than twice the weight and HP than mine. If your tires are loaded, over #6k eas
I am spoiled with excellent loamy topsoil and cheap limestone quarries 20 miles away.
   / 96” land plane suggestions? #15
Well - my topsoil isn't so bad - where I have some. Common joke around here - watch out for guys coming with a pickup truck. They will steal all the topsoil you have on your 80 acres.
The one good thing. If I need a solid base for a foundation - don't have to go far until I encounter solid, basaltic lava bedrock.
LOAD OUT AND SHIPPING (A57453)
LOAD OUT AND...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A57453)
2015 Freightliner...
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
