955 won't crank after running strong..
   / 955 won't crank after running strong.. #1
StrmChzr
Spring Hill, KS
1995 JD 955
I was helping a buddy clear out the woody drainage beneath his pond dam yesterday and turned my tractor off then wasn't able to restart it.. I had pulled a few logs out of drainage basin with a chain attached to my FEL when I decided to turn tractor off so we could saw large log into more manageable pieces. I was on a slight incline perpendicular to slope, so I stayed on tractor while log was being sawed. When I tried restarting tractor a few minutes later, my 955 wouldn't crank??? Lights came on, but no nothing after that (no starter click or anything).
I didn't have any tools onsite so I'm headed back to property today with voltmeter, jumper wire, and toolbox to try troubleshooting issue. I don't feel like its electrical problem as tractor fired up immediately and ran incredibly strong just prior to me turning engine off?? It seems like i've tripped a "kill switch" safety mechanism, but whadaiknow???
Any thoughts or insight for me?
   / 955 won't crank after running strong.. #2
Leaving it in a gear (or close) would be first thing to come to mind. Good luck getting it started with booster.
Just thinking out loud, but would a hydrostatic tractor have a gear to be left in? I'm not super savvy with tractor technology, so wondering if this is something I overlooked? I did notice the forward pedal seems slightly compressed (i.e. not flush with reverse pedal) and when i tried to pull it back, i think the reverse pedal moved opposite direction and I don't feel like either forward/reverse pedals ever returned to "normal"...
When I turn key to ON, oil light and battery light turn on, but when I turn key to START the oil light and coolant light turn ON, battery light turns off, and motor doesn't crank whatsoever...
   / 955 won't crank after running strong.. #4
Yes it does. It must be in N (neutral). Ensure that the parking brake is on, or that you're seated with the brake depressed (for safety reasons).
On my 4105 (High/Neutral/Low) there's a bit of a 'semi' position that fools me at times. I just shift it a bit to make sure it's in the correct position.
   / 955 won't crank after running strong.. #5
I would also make sure you did not bump the pto lever.
   / 955 won't crank after running strong.. #6
My 855 has failed to start on occasion and the problem is in the ignition switch or contacts on the ignition switch plug. When it happens I can spray the switch and contacts with WD40 and pull the plug off and on and it will start again until it doesn't. I can also jump it at the starter and get it to crank. It has happened 3 times but not in a few months.
Going to replace the switch soon since I broke the key off in last weekend.
   / 955 won't crank after running strong.. #7
Are all of your cables tight and clean for the battery and starter? I once had a ground cable on my 855 (from the engine to the frame I believe) that was loose and caused similar symptoms.
Quick update:
My buddy tried booster jumping the starter while I was sitting on tractor with brakes depressed in case it came to life, but no such luck... When connection was made there was sparks but starter didn't crank... I removed starter and battery to take them in to have tested at local auto parts store today...
   / 955 won't crank after running strong.. #10
Sounds like a safety interlock issue.
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
Top Hat Bumper Pull Trailer (A53117)
Top Hat Bumper...
2013 BMW X5 xDrive50i AWD SUV (A53424)
2013 BMW X5...
