955 tach and hour meter not working
   / 955 tach and hour meter not working #1
Bjohn
JD955
Anyone have any suggestions what to check first on a tach and hour meter on a 955, just bought this tractor and not sure whether it might be the cable, tach of both.
   / 955 tach and hour meter not working #2
Do you have an automotive style multimeter? If you do, you could check the tach signal at the wire-meter connection, and then at the wire-engine connection. This would let you know if the problem is in the engine, in the wire or in the meter.
The wire-meter connection point is obvious, but I have no idea where the wire-engine connection is located.
Dave
   / 955 tach and hour meter not working #3
Bjohn - It's best not to post the same question in multiple forums. You got several responses to your question in the parts/repairs forum. I think the 955 has a mechanical tach rather than electronic. Check the cable.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
John Deere XUV620i (A50121)
John Deere XUV620i...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Propane Tank (A50121)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
