955 John deere with 72" deck
/ 955 John deere with 72" deck #1
Stevend510
Barbourville
955 John deere
Please help. I'm not sure if this is in the right place or not. I'm not the savviest Internet guy there is.
my dad took the gearbox apart on my mower and now he isn't sure how it goes back together. I need to replace two bearings and a rear seal. Does anyone have an exploded diagram of my gearbox so I can get it back together or know where I can get one? My deck model number is Moo297x131995
Any help is greatly appreciated. If this isn't in the right place to post this please let me know where to post it. Thanks
/ 955 John deere with 72" deck #2
Go to this web site. John Deere - Parts Catalog. In the search blank type in 955 and press find. Click on 955 compact utility tractor. It will open up another menu. At the top of the menu it have a line called implement. Click on that and you should be able to find a line that lists 50, 60 and 72 inch mowers. I like to use the sectional index so that's what I click on. If you've listed the right serial number the right menu would be the 4th one. Click on "54 - gear case" and you should open the right parts diagram for your mower. You can print off any part of the parts diagram that you need. Good luck.
Thank you sir! That's exactly what I need.
