Oil & Fuel 955 front axle seeping oil
   / 955 front axle seeping oil #1
Acehardly
Amissville, Va
L & G 345, X595, 2305, 955 W/FEL
I found a drop of oil on my garage floor and discovered that my front right axle is seeping gear oil. It doesn't seem to leak all of the time but it does seem to keep showing up. I attached a pic of the axle and it looks like seal # 8 is the seal that is leaking. Anyone replaced this seal or know if it could be worse than just replacing this seal?
Thanks...
Tony
   / 955 front axle seeping oil #2
That's not a bad fix, under 2 hours the first time, under an hour next time. Make sure you have a decent pair of circlip/snap ring pliers, (internal and external).
Thanks for the info. I have both, and should be taking this on within the next week or so. I hate leaks....
   / 955 front axle seeping oil #4
Same for an 855? Mine appears to be weeping from the same location. Not badly, a touch on teh sides of the housing. No time so I make sure it's topped off and flush it clear now and a gain to be sure it's not getting worse.
I'm pretty sure the 855 is the same.
Okay, I got it apart without having to remove the whole shebang. I just removed the tie rod control arm and there is the seal. I was told by the dealer that I should replace # 7 (Seal Bushing) also. Does anyone know if this is a pressed on bushing or should it pretty much slip off?
I'm thinking that it is pressed because it is another way for oil to get out otherwise.
I noticed something else, there is a clicking noise when I spin the hub by hand. Is that normal?
Thanks in advance.
Tony
   / 955 front axle seeping oil #7
Some clicking is normal. It is the normal meshing of the gears. Is the clicking uniform?
Yes, it is very uniform. Although. It doesn't seem to do it if I turn it slow.
Well, I finished it. It was quite easy, I was able to do it by only removing the top control arm while supporting the bottom knuckle. I removed the sleeve bushing which has a rubber inner race and the seal. Put it all back together. I reckon it will only take me about 20 mins next time I do it.
Thanks for all of your help!!
Tony:thumbsup:
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Honda UTV (A56859)
Honda UTV (A56859)
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
