9400/5020
/ 9400/5020 #1
crowspond
John Deere 5020
Does anyone know if a flywheel from a 9400 [12.5L] will bolt up to a 532/619ci engine crank ?
/ 9400/5020 #2
Crow,
Apparently you are new to Deere. Accurate information is nearly impossible without:
1) tractor serial numbers
2) engine serial numbers
3) any part numbers on the castings
I'm showing 4 different flywheels for the 5020. Please explain your problem.
/ 9400/5020
I think you are the one who is new to Deere because a flywheel from a 1968 5020 will fit a 6030, 8630, 8640, 8650 [all big blocks] and as far as my problem, read my first post again.
/ 9400/5020 #4
Seems like you've got it all figured out. Good luck with your problem.
2009 BMW Sedan (A61569)
2009 BMW Sedan...
Giyi Auger (A62183)
Giyi Auger (A62183)
2018 Kubota L3901 (A62180)
2018 Kubota L3901...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63118)
2022 Schulte...
2017 Hino 268 (A62180)
3015 (A56857)
3015 (A56857)
