9400/5020
   / 9400/5020 #1
crowspond
John Deere 5020
Does anyone know if a flywheel from a 9400 [12.5L] will bolt up to a 532/619ci engine crank ?
   / 9400/5020 #2
Crow,
Apparently you are new to Deere. Accurate information is nearly impossible without:
1) tractor serial numbers
2) engine serial numbers
3) any part numbers on the castings
I'm showing 4 different flywheels for the 5020. Please explain your problem.
   / 9400/5020
I think you are the one who is new to Deere because a flywheel from a 1968 5020 will fit a 6030, 8630, 8640, 8650 [all big blocks] and as far as my problem, read my first post again.
   / 9400/5020 #4
Seems like you've got it all figured out. Good luck with your problem.
John Deere 47" Snowblower (A50774)
John Deere 47"...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
Reel Mower Tractor Attachment (A50322)
Reel Mower Tractor...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2014 Peterbilt 337 Forestry Grapple Truck (A50323)
2014 Peterbilt 337...
Wood Fence Posts (A50121)
Wood Fence Posts...
