'93 Kubota L4350 electrical problem
   / '93 Kubota L4350 electrical problem #1
Levi63
Green Bay, Wi.
Kubota L4350
Hello everyone. I have a problem with my L4350. The issue with the tractor is it doesn't charge the battery, the "easy checker" dash display doesn't light up, glow plugs do not warm up, fuel and coolant gauges do not work and when I turn the key off it will not shut of. I have to pull the fuel shut off knob. I had the alternator and regulator bench tested by a rebuild shop and they both checked ok. Any help would be great. Thanks for your time.
   / '93 Kubota L4350 electrical problem #2
A wiring diagram would be helpful seems as your not getting power to dash check and see if you have power to fuse panel and check and see if it has a fuseable link find out what has power and where it stops at good luck.
   / '93 Kubota L4350 electrical problem #3
What Rocky said, and look for rodent damaged wiring harness, corrosion at fuse box, blown fuses, etc.
Thanks, a place to start.
   / '93 Kubota L4350 electrical problem #6
Where are you at with the problem? Any progress?
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2013 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F77DUB50591 (A51572)
2013 Ford Escape...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A52748)
UNVERFERTH 330 -...
NEW Work Saver Skid Steer/Sub Compact Grapple (A52748)
NEW Work Saver...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
