9220 transmission overfilling
   / 9220 transmission overfilling #1
jd1985man
Binger, Oklahoma
John Deere 9220 2007model
I have a 9220 JD my transmission oil level rise to overfull about every 50 hours. I just recently had the clutch replaced and all new O-rings put in the hydraulic pump. Jd dealer thought this would fix the problem. Just wondering if anyone else has had this problem and if oil could be getting in from somewhere else like the steering cylinders?
   / 9220 transmission overfilling #2
You would think if it is rising in the transmission that it would have to show up as falling somewhere else.
If you have cavitation in the system air entrainment may be the culprit as the air bubbles would seem to make the level read higher. I would check this next time it is reading over filled by shutting down for 30 minutes and then recheck. That would give the air bubbles time to surface.
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2005 INTERNATIONAL4300 WRECKER (A53426)
2005...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
