92 kubota L3450 with loader and backhoe
   / 92 kubota L3450 with loader and backhoe #1
bruno_rs
hey all, i just bought a L3450 and was wondering if someone can tell me the approximate weight of the machine, with the loader and hoe? i have a 16 ft. 7000lb trailer... will that be enough? thanks, looking forward to hearing from you. have a good one.
   / 92 kubota L3450 with loader and backhoe #3
I looked up your tractor and it tips the scale at 3,000#. My 28 HP tractors FEL weighs 810# so lets say yours weighs 1,000# being a 33 HP tractor. Most 3 point BH this size weight about 1,200#. So this should have you at 5,200#. My 18' trailer weights 1,400# empty so yours is probably 1,200# to 1,300#. You will be right at the max our slightly over. Don't forget to add in the weight or your chains, shovels, ect.
Chris
Chris
thanks em14 and chris. i thought i'd be at or close to the max. do you think it may be time for a bigger trailer?
   / 92 kubota L3450 with loader and backhoe #5
Yes, probably time for a bigger trailer. What are you towing with? The big problem with this tractor and trailer combo is having the deck room to get the load situated right to level out the load. I would go to at least a 20' trailer with 5,200# or 6,000# axles. But again it depends on your truck. Remember, your trailers GVWR can not exceed your trucks towing capacity even empty. Example is a 1/2 ton truck with a 9,000# tow rating can not tow a 12,000# trailer with your load on it. If you have a 3/4 ton truck or bigger you will be ok as long as its not a gas V8 version.
Chris
Chris
hey chris, thanks for the quick response. i have an 84 chevy k30 1 1/4 ton (1008 CUCV military) pick up. i also have an 84 chevy 1 ton (1009 CUCV) blazer. i'm looking to pick up the machine in the next few days and would prefer using the blazer. trailer and machine shouldn't weigh more than 7000lbs (+/-). curious about your last sentence... i could use a 3/4 ton truck or bigger but not gas?... why not gas v8 version? does this have something to do with the need for a cdl (trailer/equipment over 10k)?
   / 92 kubota L3450 with loader and backhoe #7
No, the gas V8 statement was saying the current 3/4 ton trucks with a gas V8 usually have a tow rating of 10,000# or less so they will not work for your needs. You would need a diesel or one of the larger V8's or the V10's from Ford or Dodge. You should have no problems with these heavy duty trucks you have but check the tow ratings in the owners manuals to be sure. If your truck does not have a manual or no section on towing check the data plate for the GCVWR and subtract the trucks weight and this will give you the tow rating. For example my F-350 has a GCVWR of 23,000# and weighs 7,600# with me in it and 3/4 tank of fuel. So in this case the tow rating is 15,400#.
Chris
thanks chris, i appreciate your help and quick responses
2009 MACK CXU613 DAYCAB (INOPERABLE) (A50854)
2009 MACK CXU613...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
PAIR OF 29 FT PIPE RACKS (A50854)
PAIR OF 29 FT PIPE...
Unused 2025 CFG MX15RX Mini Excavator (A49461)
Unused 2025 CFG...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
