917 flail mower
   / 917 flail mower #1
Oh henry
2638 mahindra
Hello I just got a 917 flail mower it has 3 rows of 14 corse cut knifes it is out of balance does. There's multiple holes for mounting does anyone have info how to put it back correctly? I am not sure if it's corse cut or fine cut mower
Mike Henry
   / 917 flail mower #2
It is a course cut mower and can use fine cut blades. I can take a picture of mine tomorrow
   / 917 flail mower #3
Here are some pictures of my 71" mower
   / 917 flail mower
Awesome thanks
   / 917 flail mower
Hey my next question is the drive pulley is there anything specific on getting it off I noticed last night the drive pulley is off not in line with the rest of the drive system it cruves out I need to see about getting that aligned.
   / 917 flail mower #6
If I remember right, it is on a tapered, keyed shaft. A good puller will get it off.
   / 917 flail mower
Awesome thanks not sure if it can be pushed back but going to try
   / 917 flail mower #8
The pulley is not loose? You need to take it off and see what shape the key and shaft are in to see why it has come out like that.
And, just to be clear, it is the bottom pulley for the rotor that has come out, not the top drive pulley.
   / 917 flail mower
Update i took the blades off still has vibration. I pulled the bottom pulley off it looked fine the whole cutter shaft slides back and forth.both bearings looks good.going to order new ones. I am stumped lol I'll also take it to drive shaft shop to have it balanced. My question is what keeps the shaft from sliding back and forth am I missing something?
   / 917 flail mower #10
The bearings on the rotor have locking collars to keep it from walking back and forth.
Are there a stack of weights bolted on the inside end of the rotor?
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2004 Jeep Grand Cherokee SUV (A50324)
2004 Jeep Grand...
