914A MMM: The honeymoon's over!
   / 914A MMM: The honeymoon's over! #1
KYTurkey
Northwest Kentucky
NH TC24DA
914A MMM: The honeymoon\'s over!
Well, the MMM is broken. /forums/images/graemlins/frown.gif After asking about leveling and reading everyone's replies, I finally left it completely alone, except that I moved the 3-point lift arms to their highest position (as per the manual and suggestions here). I called the dealer and they offered to look at it, but it meant renting a trailer and hauling it an hour each way.
Guess I should have rented the trailer, because now one of the lift rods is snapped in two:
As you can see from the second picture, the deck pin apparently either broke or fell out when the rod snapped, as well. All I know is that everything was fine, I lifted the mower to drive down the driveway, got to where I was going to mow and dropped the deck, and one side of it went "clunk." When I lifted it back up that side stayed down. /forums/images/graemlins/ooo.gif
So, the dealer's driving down for a look-see sometime this coming week, and I'm out of the mowing business for a while. /forums/images/graemlins/grin.gif
   / 914A MMM: The honeymoon's over! #2
Re: 914A MMM: The honeymoon\'s over!
Can you just replace that piece of threaded rod? Is something else missing? I had a similar failure on my Cub 5252, a pin fell out. I replaced it with a bolt and found the pin in the driveway a week later!
Good Luck
Curt
Unfortunately, it's not just a simple threaded rod...it's a long piece of rod, threaded on both ends, with a zigzag in the middle. It'll have to come from the factory. /forums/images/graemlins/frown.gif
   / 914A MMM: The honeymoon's over! #4
I'm only guessing, but my experiences with deck pins leads me to believe that the deck pin fell out first and that may have contributed to the rod snapping. I have lost my share of deck pins until I got smart and used a different clip.
2013 Lexus ES Sedan (A50324)
2013 Lexus ES...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
Cat TH407C Telehandler (A52748)
Cat TH407C...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
