914A MMM tension spring
   / 914A MMM tension spring #1
kgoring
I just replaced the belt on my 914A MMM 72" deck. The last step is to adjust the tension on the spring so the spring length is 5-9/16". With the adustment arm extended to its fullest, I'm still over 5-9/16". I bought this tractor used so now I am wondering if anyone else has run into this issue or if the previous owner put a different, longer tension spring on this mower. Any input?
   / 914A MMM tension spring #2
Are you sure you have the correct belt. Greg
Yes, I have the right belt. The old belt (stamped with factory part number) was the same way. It also appears that even with the spring "overstretched", the belt is very loose and flaps around quite a bit. But it cuts nice.
   / 914A MMM tension spring #4
recheck belt routing; can be tricky.
Year: 2011 Make: Kia Model: Forte Vehicle Type: Passenger Car Mileage: 172,391 Plate: Body Type: 4 (A51694)
Year: 2011 Make...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
NEW Wolverine Skid Steer Bucket Root Rake Attachment 34'' (A53002)
NEW Wolverine Skid...
WESSEX CRX 180 LOT NUMBER 171 (A53084)
WESSEX CRX 180 LOT...
