914A MMM tension spring
   / 914A MMM tension spring #1
kgoring
I just replaced the belt on my 914A MMM 72" deck. The last step is to adjust the tension on the spring so the spring length is 5-9/16". With the adustment arm extended to its fullest, I'm still over 5-9/16". I bought this tractor used so now I am wondering if anyone else has run into this issue or if the previous owner put a different, longer tension spring on this mower. Any input?
   / 914A MMM tension spring #2
Are you sure you have the correct belt. Greg
Yes, I have the right belt. The old belt (stamped with factory part number) was the same way. It also appears that even with the spring "overstretched", the belt is very loose and flaps around quite a bit. But it cuts nice.
   / 914A MMM tension spring #4
recheck belt routing; can be tricky.
2018 TAKEUCHI TL12V-2 SKID STEER (A51246)
2018 TAKEUCHI...
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
1989 Chevrolet Corvette Passenger Car, VIN # 1G1YY318XK5111655 (A51572)
1989 Chevrolet...
2016 R&R Products 331 LP Reel Mower (A51691)
2016 R&R Products...
