</font><font color="blue" class="small">( I use a 2"x4"x18" block of wood wedged between the mower deck diverter/curved frame members and the blade to block the blade from rotating. that and a cheater bar on the 13/16" wrench works great.
Anyone out there had there blade unwind and set itset down on the ground, bolt and all when turning off the PTO? /forums/images/graemlins/shocked.gif That teaches you to use the cheater bar when putting the blade back on, too! /forums/images/graemlins/grin.gif )</font>
Even using the block of wood the inside shaft will still turn. I use a cheater bar, block of wood and will even lock a vice grip on the pulley tight inside the belt. That seems to work the best for me. And once I have off and re-installed, I will mow once then lift my deck up again and re-tighten. That way I don't worry so much about them coming loose.
murph
