914 mmm greasing
   / 914 mmm greasing #1
BeeFarmer
S.E. Ohio
TC 33D
Just wondering how much grease do folks put in the blade bearing fittings on a 914 mmm. I've heard you can over grease them... A friend of mine puts 6 - 7 pumps where my brother in-law does 15 - 20... anyone have the right number and I know it probably depends on the grease gun.. .
   / 914 mmm greasing #2
I've been greasing things for years and I always put 3 shots from a hand pump unless I'm repacking after installing new or cleaning. I've never had a bearing failure due to lack of grease. you're milage may vary. /forums/images/graemlins/smirk.gif
   / 914 mmm greasing #3
To me 6 - 7 pumps seems high. I usually go with about 3 max as long as you stay on the right schedule along with the manual.
murph
   / 914 mmm greasing
Can you over grease these bearings?
   / 914 mmm greasing #5
I believe any bearing can be overgreased? Maybe one of the experts could chime in here.
murph
   / 914 mmm greasing #6
I use a Arrow power greaser and put 2 pump cycles in before EVERY mowing.
Over greasing if it comes out on top could get on belt and cause slippage.
Just like putting too much grease in the throw-out bearings on manual transmissions could get on clutch brake or the disc.
I mainly grease every time to keep wheels lubed.
I've never heard of overgreasing hurting a bearing.
   / 914 mmm greasing #7
<font color="blue"> I've never heard of overgreasing hurting a bearing. </font>
Neither have I, which doesn't mean much! /forums/images/graemlins/grin.gif
I usually grease until it comes out the little hole in the bottom of the spindle.
   / 914 mmm greasing #8
Overgreasing causes the grease in the housing to churn like in a blender. This causes excess heat and premature seal and bearing failure. There needs to be room for the grease to move without being in constant churning motion. Once you've greased a tapered roller or straight roller bearing you should be good for numerous times of use. Compare this to you car wheel bearings, many are NEVER greased or only when a brake job is performed. My recommendation is to grease your mower deck spindle bearings 1 to 2 times per season. Wheels can be greased much more frequently because they don't rotate at the same velocity or generally have the same sealing capability.
   / 914 mmm greasing #9
Even w/ my every mowing grease job the top and bottom of the mower show very little excess grease around them.
Your spindle bearings turn at 3000+rpm vs 5-600 rpm for car bearings.
We have an early '80 IH284 w/ woods belly mower, '84 Continetal Belton 5' mower and had a 7+year old woods RFM than didn't have any problem w/ our greasing plus they are in great shape yet after mowing 5 - 7 acres every mowing.
We only use Schaeffer moly grease too which won't mix w/ water like lithium base grease and gives the blender look to the grease when it gets water mixed in it.
EZ loader trailer (A56857)
EZ loader trailer...
2013 Chrysler Town and Country (A56859)
2013 Chrysler Town...
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
PALLET TOTE OF SINKS (A58374)
PALLET TOTE OF...
2017 Ford F-150 Pickup Truck (A55973)
2017 Ford F-150...
