9 years from my original Battery
   / 9 years from my original Battery #21
I used to get 4 years out of a battery and called it good. Then I discovered the new "smart" chargers that also repair and desulphate the battery. I charge each fall late in the season and now I get 10, 11 and 12 years out of good batteries. Those old high power chargers just cooked the dickins out of the battery and killed more than they cured is what I have learned. There are others but I have a Genius 3.5A and paid around $68 for it. I'm never going back. There are other threads on smart chargers.
I've had one of those chargers for years...They work great in re-condition mode.
   / 9 years from my original Battery #22
Following this thread, got my BX2660 in 09/2008, central VA, still starts easily with original battery.
   / 9 years from my original Battery #23
Got 10 years out of my original TC30 battery. It helped that I plugged it in over the winter - made starting easy!
   / 9 years from my original Battery #25
The original battery in my brand new 1982 Ford 1700 lasted eleven years. The replacement - which was supposedly the same quality - lasted four.
Ain't technology grand.......... Industry has learned and adroitly applied the technology - engineered obsolescence. Its a real money maker.........
   / 9 years from my original Battery #26
Dont think Ive ever had a battery last that long in my lifetime.
Any particular make that most are using as a replacement? Original kubota battery just too high dollar for me :(
That's really impressive for being in TX. 10 years is no big deal up here in the cold climates, but almost unheard of down south. I finally had to change my L4200's battery this past fall after 12 years - and that was a replacement. I get my batteries at Sam's Club - Duracell. I get the highest cranking amp battery that will fit into the slot - I think my new one is 1100 CCA.
   / 9 years from my original Battery #27
Got a 2002 Kubota that still has the battery it came with when new. I dont recall ever having to jump it.
   / 9 years from my original Battery #28
I just replaced the battery in my2012 Rhino with around 150 hr on it, and it was gone, wouldn't even restart after plowing snow for a hr. Tractor kabota battery is 10 yr, 8 months old with little over 1000 hr on it, cold starts are always done with block heater on, 20* or less, but it showing signs of slow starting, without block heater on I dont think it would start on even turn motor over, makes me wonder if the old battery is still giving full heat to the glow plugs, seems like now I have to hold the key back longer than I use to.
   / 9 years from my original Battery #29
As far as I know, the big 1100 CCA's like that are only available in the north. I used to get them in Maine but down here I'm lucky to find a 950 CCA. Big CCA batteries are definitely an advantage to a cold climate.
   / 9 years from my original Battery #30
I had a similar situation, About 9 years out of the factory battery on my Harley, that also was no "maintainer" in the 5 month winter season like I should have. I went ahead and spent the $tupid money for another HD battery, only a few years on it now.
LOT: (2) Piece Mac Tools TRCH Portable 1000 Tool Box w/Contents: Lower Tool Box: 18-Drawers, Upper (A59076)
LOT: (2) Piece Mac...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
UNUSED FUTURE XKH39 39" HYD MINI HYD 4IN1 BUCKET (A58376)
UNUSED FUTURE...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
7 SHANK ALL PURPOSE PLOW (A58375)
7 SHANK ALL...
18-Drawer Stationary Tool Box w/Contents, 67" W x 24" D x 80" H (A59076)
18-Drawer...
