9" snow pusher or 9' snowplow?
   / 9" snow pusher or 9' snowplow? #1
screamin400
Platinum Member
Lee Center NY
2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
I am going to do some plowing this winter commercially and residential. I believe the pusher is pretty much straight line unless I get one with hydraulics. The blade has some nice features but I feel would be more suited for residential than commercial? When using a blade that is angles how much does your front slide around with r4 tires? Thanks
I am considering my 7' box blade on the back to pull the snow from in front of buildings and then push away with the pusher. I also have a rear blower but cannot take both.
   / 9" snow pusher or 9' snowplow? #3
I bought a 7' pusher when I bought my tractor. The pusher works great if going in a straight line but found I couldn't turn with the pusher full. Not so good for driveways with curves. My 7 1/2' PA plow works great for driveways. I have a 7' rear blower, loaded tires and chains if needed to use also. Sold the pusher.
I have seen online PA blades that have swing out sides to use as a pusher. Sounds like that would work for you. Snow Ex swing blade and Avalanche hydraulic pushers come to mind.
   / 9" snow pusher or 9' snowplow? #4
I do no plowing for hire but have enough to keep me busy if we get much snow. BIG yard - mile long gravel driveway - mail box area. I do it all with my rear blade. I have two blades because the lighter of the two will not "penetrate" my concrete hard driveway in the summer.
One of these days I will get around to selling the lighter rear blade - Land Pride - RB3596 @ 565#. My new rear blade - Rhino 950 - 96" - 1050#.
   / 9" snow pusher or 9' snowplow? #5
Pushers are for parking lots.Plow for everything else;I use and 8ft.front blade and a 7ft.rear blade(not box).
   / 9" snow pusher or 9' snowplow? #6
You already have a blower, so I'd say a large front blade to carry both. Be sure to get a front blade that floats on it's own and articulates so you can keep the FEL arms lifted somewhat to get much better traction. That also takes the full weight off the plow's cutting edge and greatly reduces any side push.
Pricing an 8' Mahindra front angle snow blade today. I am leaning in that direction right now mainly for residential. Wider may be too wide for a homeowners driveway
   / 9" snow pusher or 9' snowplow? #8
To use an angling blade you need weight, like a heavy tractor, not a CUT.
If you get lots of snow you need to start real wide as when winter progresses the drives get narrower and U then need a blower to widen.
Angled blades work great on a plow truck because you have speed to curl that snow away and even then in heavy sow areas yo soon run out of space.
An ideal situation is a rear blower combined with an angled blade for the minor events (like 3" or so).
Pushers (blade with wings) are for large areas like parking lots.
My 20 HP CUT had an angling blade that I soon converted to straight push and added a wing on one side only. This way any spillover always goes to the side that I want otherwise I had 2 spillovers to contend with. Saves time on my large areas.
Fact is I actually demolished my front rims as the angled blade caused the front wheels to always be crabbing.
   / 9" snow pusher or 9' snowplow? #9
I have a 1000' gravel driveway and use a plow I bought from QuickAttach that converts to a pusher with retractable wings. Like nybirdman said, pusher's are for parking lots, you'll use the blade much more than the pusher in residential use. P1060004.JPGP1260005 (4).JPG
   / 9" snow pusher or 9' snowplow? #10
Stay away from any plow that is rigid mounted to the quick-tach plate. A snowplow needs to be able to float with the contours of the ground like it does on a plow truck with a chain for a top attachment to lift it. If it's rigid mounted then you have to constantly adjust the height unless you have just a flat driveway. If you rely on the loader float function then you lose front wheel traction (and steering traction) because the weight of the loader itself is shifted to the blade instead of keeping it on the front wheels.
I'm currently building one for my 2655 using an 8' fisher plow. I thought about going 9' too but just don't need that extra width and got an awesome deal on the 8' plow on craigslist. I also plan on running chains on all 4 wheels since after the first storm of the year my driveway is more like an ice road.
Set of AG R4 Wheels and Tires (A52128)
Set of AG R4...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 78"...
2002 Trotwood Trailer (A50515)
2002 Trotwood...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
UNUSED X-STAR 250 GALLON FUEL TANK (A51243)
UNUSED X-STAR 250...
