8n with a 72" finish mower
   / 8n with a 72" finish mower #1
ezzy
tennessee
1952 Ford 8n
8n with a 72\" finish mower
how much horse power does an 8n have and is it enough to pull a 6' finish mower
   / 8n with a 72" finish mower #2
Re: 8n with a 72\" finish mower
I have used that setup for a couple of years. The 72 is ok under ideal conditions, but if you miss mowing one weekend you will be picking the mower up much of the time. It will also imphasize the shortcomings of the none live pto and hydralics. In short, if that is what you have use it. If I were buying a new finish mower, I would buy a 60.
   / 8n with a 72" finish mower #3
According to the I&T service manual, which has its info from the nebraska tests. The 8n has 27.x belt hp.. and about 23.x pto hp. 9n and 2n tractors have a fraction less hp, due to a lower compression ratio ( 6:1 9/2n 6.5:1 8n ).
Lots of people run 6' finish mowers on there N's. Some like 5's if their lift is weak. If you are getting too much of a bit on the 6' swath.. just cut 5' or 5.5'
Soundguy
   / 8n with a 72" finish mower #4
Here's the info from your other post in the other forum.
Soundguy
   / 8n with a 72" finish mower #5
i had a 2n with a 6ft mower, it worked okBUT if the grass got out of hand it struggled, and not having live pto just made it worse. so u might have to take smaller cuts at times. but for most conditions it should be ok.
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
Test Button (A47384)
Tool Box (A47384)
Tool Box (A47384)
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
2009 Chevrolet Cobalt Sedan (A50324)
2009 Chevrolet...
Steel Flatbed (A50515)
