8N Valve Adjustment Procedure
   / 8N Valve Adjustment Procedure #1
8NKen
If anyone could post a step-by-step procedure of how to adjust the valves on an 8N I would really appreciate it. I've got a fair amount of mechanical ability and the I&T manual, but the procedure listed in that book is a bit lacking. I already have the special tools needed for this job. The guys at the local dealer were real resistant to give any service advice. The service manager would just get mad and quote their labor rate. So, I also went elsewhere for parts. Probably part of the reason they went out of business. Thanks for any help.
Ken
Clarksville MI
   / 8N Valve Adjustment Procedure #2
Do a search for "ntractorclub.com". I think they can help you....BobG in VA
   / 8N Valve Adjustment Procedure #3
don't you have to grind them to spec like most of henry's flatheads? if so, order you a set of adjustable tappets......won't be too much for a 4 cyl.
   / 8N Valve Adjustment Procedure #4
Also.. get an I&T fo-4 manual.. good infor in there for servicing the tractor.. etc.
soundguy
707A (A51692)
707A (A51692)
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2015 Volkswagen Passat Sedan (A51694)
2015 Volkswagen...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
2022 Mercedes-Benz Sprinter 4500 (A51692)
2022 Mercedes-Benz...
