8N Valve Adjustment Procedure
   / 8N Valve Adjustment Procedure #1
8NKen
If anyone could post a step-by-step procedure of how to adjust the valves on an 8N I would really appreciate it. I've got a fair amount of mechanical ability and the I&T manual, but the procedure listed in that book is a bit lacking. I already have the special tools needed for this job. The guys at the local dealer were real resistant to give any service advice. The service manager would just get mad and quote their labor rate. So, I also went elsewhere for parts. Probably part of the reason they went out of business. Thanks for any help.
Ken
Clarksville MI
   / 8N Valve Adjustment Procedure #2
Do a search for "ntractorclub.com". I think they can help you....BobG in VA
   / 8N Valve Adjustment Procedure #3
don't you have to grind them to spec like most of henry's flatheads? if so, order you a set of adjustable tappets......won't be too much for a 4 cyl.
   / 8N Valve Adjustment Procedure #4
Also.. get an I&T fo-4 manual.. good infor in there for servicing the tractor.. etc.
soundguy
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2017 John Deere 9009A 4WD 114in 5-Deck Fairway Mower (A51691)
2017 John Deere...
Scag Mower (A50324)
Scag Mower (A50324)
CFG Industrial SAII100 (A50123)
CFG Industrial...
