8n steering
   / 8n steering #1
tessiers
Platinum Member
Central Maine
05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
My 8n has a steering problem, new style steering box, when I turn the wheel the steering shaft moves up and down as much as an inch. Could this be as simple as bearings, or do I have bigger issues. I am gonna tear it down, possibly this weekend.
   / 8n steering #2
I had the same problem with mine wheel moved up and down when you turn and a lot of slop. The top bearing was worn out from lack of oil new bearings and it works like new. Refill with JD corn head grease it won't leak out like the 90w oil.
   / 8n steering #3
yep.. top thrust bearing is likely gone.
need to pull the tin, bat box, and dash. get the box top off. fish all the old rollers out. intall a new bearing. check the cup. re-assemble. adjust backlash.. pack with 0 or 00 ep grease.
make sure you pay attention to preload on thrust bearing using shim stack under box top.
   / 8n steering #4
Needs a new bearing. Stay away from the new fangled plastic ones
   / 8n steering
thanks guys, that eases my mind a little, I already have all the bearings.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
BOMAG BW213 SMOOTH DRUM ROLLER (A58214)
BOMAG BW213 SMOOTH...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
