8n runs breifly then abruptly shutsdown
   / 8n runs breifly then abruptly shutsdown #1
slapshot
Lincoln County, Missouri
'51 Ford 8n
I have a '51 8n that when its cold will start and run for 20-30 seconds or so then shuts down abruptly. While its running is fairly rough and squeals real loud like a fan belt. I've removed the fan belt and it still makes the same noise.
It does this while the clutch is in so I dont think its anything back half related.
It has oil. it has new wires plugs, coil, condenser and rotor. I have not dropped the oil pan yet to take a look, no fun when its 15 degrees.
Kinda stumped, crankshaft bearing? distributor shaft?
Thanks
-dave
   / 8n runs breifly then abruptly shutsdown #2
Have you checked the action of the choke or the height of the float in the bowl.
Craig Clayton
   / 8n runs breifly then abruptly shutsdown #3
If you've got a squeal when all of your belts are off then you've got metal on metal somewhere. I guess your starter could be hanging up also. Does it sound internal? Is the crankshaft pulley rubbing on anything?
   / 8n runs breifly then abruptly shutsdown #4
I have been reading the other suggestions and what is the thickness of the engine oil
Craig Clayton
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
205113 (A52706)
205113 (A52706)
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
30056 (A53424)
30056 (A53424)
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
