8n rims
   / 8n rims #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Anyone know if the 16 inch rims on my 8n can be replaced with the taller ?19's that i have seen on other N's?
Is the bolt pattern the same and the hub? Or will I have to cahnage hubs?
Soundguy
   / 8n rims #2
I bet this question was asked a lot in reverse when people wondered if they could replace the original equipment 19 inch wheels with the 16 inch implement wheels you now have on your 8N. ;)
   / 8n rims #3
I could not even tell you how many (removed) tractors that my dad converted to 16" tires in front by cutting the centers outa the 19" wheels and welding them into an automobile wheel. We never had a Ford in our tractor stable but the neighbors all around us did. As soon as they had to buy new front rubber, away went the 19" tires and wheels.......especially if they got a front end loader. In those days, WAGNER loaders were the cats pajamas for the ferds and fergies. You know the ones.....where you climbed UP and OVER to get down to the cockpit.
   / 8n rims
<font color=red> bet this question was asked a lot in reverse when people wondered if they could replace the original equipment 19 inch wheels with the 16 inch implement wheels you now have on your 8N. ;)
<font color=black>Great, thanks.
Soundguy
   / 8n rims #5
you have to swap the hubs if i remember right, the 19" ran the old model a ford bolt patern with the large center. the 16" was small center hole and smaller bolt pattern.
   / 8n rims
I've heard that the 9N's had a different bolt pattern.. 5 lugs, but that the 6 lug 19" rims should fit the 8N... In any case, I'll know tomorrow morning.
Soundguy
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
