8N rear axle
/ 8N rear axle #1
gspig
Due to a dangerous and stupid loading mistake, I need to replace the right rear axle shaft. How is the shaft held in? Do I just remove a retainer plate or is there some internal retaining clip I have to take off first?
/ 8N rear axle #2
I'm guessing that you ned to pull the axle trumpet, as you might as well replace the oil seal(s) while you are in there. Old style has 1 seal.. new style has 2 seals. Axles aren't interchangeable.. so you need to know the year of your tractor, which can be found via serial number.
the N board over at ytmag.com has tons of N-formation on topics just like this.
Soundguy
/ 8N rear axle #3
after doing a bit more research.. I think it is a floating axle.. meaning.. remove the big axle nut.. remover brake hub, etc.. and i think you will be able to remove axle without removing trumpet.
Soundguy
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
1998 MAGNUM TRAILER (A65643)
1998 MAGNUM...
6' Bush Hog (A62613)
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
Sakai SW354 (A64126)
